Opening a widget from a placeholder can be done using PanelManager's showPanel method. However what if the widget is located in a controller ?
So far the only solution I found is to call the controller's method which open a given widget :
var controller = WidgetManager.getInstance().getWidgetsByName('MyThemeController');
controller.openWidget(widgetConfig);The problem with this solution is that not every theme controller implement such method.
