I'm new at this, so please bare with me. I was recently asked if I could create a map showing tax parcel color coded in to code classes (ie - > 50,000, 50,000-100,000, etc) and then have the assessment value labeled on each parcel as well. Our assessment values are in represented into the 100 place (ie - ($)120,200, ($)15,800, ($)267,800, etc.), however they have asked if I can that the labels be 120K, 16K, 268K and so forth. (essentially rounding the numbers to the nears 1000. I have found where I can pick how many significant digits should appear, but anything less than 100,000 rounds to the 100 not to the nearest 1000. (ie - $15,800 remains this as opposed to being rounded to 16,000).
Is this something that is possible to achieve with labeling or is it possible by using the field calculator? Thanks your any help you can provide me.
