Hi, I am trying to setup a portal counter which is in a HA environment.
When setting up the counter, Portal B works however Portal A returned an error. I ran the support.bat to check the logs but found nothing. Would you be able to provide some advise where can I get more information that is causing it to fail?
For example, is it possible to view the request that caused the failure?
I tested bypassing the WA (hit port 7443 directly), password doesn't contain special character.
Account used has administrator privileges.
