I am adding widgets to my view like so:
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>widget1<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-left"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>widget2<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"bottom-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
I noticed that the widgets on the top regions are stacked vertically and the widgets in the bottom regions are laid out horizontally. You can see a sample here: https://codepen.io/dschontz/pen/zgErxO
Questions:
- Can you set the flow of widgets on a per-region basis? For example, can I have the bottom-right region stack widgets vertically?
- Can I have a region flow in both directions? For example, a couple widgets horizontally placed in the bottom-right corner, and another 2 widgets placed vertically above them so that they form a kind of "corner" on the map _|.
