So I am reading...
Deploy your app—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
It talks about creating symbolic links and suggests...
ln -s $HOME/ArcGIS/<version>/sdk/OSX/x64/lib/libEsriRuntimeQt.dylib /usr/lib/libEsriRuntimeQt.dylib
A couple of things I noticed...
1) The SDK is not installed on my machine under $HOME/ArcGIS. I am running 100.5 and am pretty sure I just accepted the defaults during installation. Should this documentation be updated or is it just something specific on my machine? Or do I need to find specific documentation for 100.5?
2) I have the following path...$HOME/ArcGIS_SDKs/Qt100.5/sdk/macOS/x64/lib but do not see libEsriRuntimeQt.dylib as suggested by the above documentation. What I do have in that folder is: libArcGISRuntimeToolkitCppApi.dylib, libEsriCommonQt.dylib, and libruntimecore.dylib. Should I make symbolic links to any of these instead?
3) Whenever I try to create the symbolic link, I get "Operation not permitted". Any suggestions on how to get around this?
I'm running macOS Mojave 10.14.6 and runtime 100.5. Appreciate the help.
I must need to get the above figured out I guess because whenever I navigate to my *.app content and run manually I get...
qrc:/qml/main.qml:2:1: module "Esri.ArcGISRuntime" is not installed
qrc:/qml/main.qml:1:1: module "Esri.ArcGISExtras" is not installed
Thanks!
Jeremy
