I am buffering points and I want to put the attributes of original point on the resultant buffer polygon. I also want to add an extra attribute for 'source' to indicate which layer I was buffering.
The graphic is getting the feature.attributes from the original point. I thought I could use graphic.attr('name','value') to add the extra attribute I want. It doesn't seem to be doing anything. It's not generating any error either. Is this not the proper method?
//create a buffer graphic for every point
function generateBufferGraphic(features){
bufferLayer.clear();
var radius = registry.byId("bufferSelect").value;//user can select buffer distance
var idPoint,circle;
arrayUtils.forEach(features, function (feature){
idPoint = feature.geometry;
circle = new Circle({
center: idPoint,
geodesic: true,
radius: radius,
radiusUnit: "esriMiles"
var graphic = new Graphic(circle, bufferSymbol,feature.attributes);
graphic.attr('source','layername');
bufferLayer.add(graphic);
