Is there a way to identify which map instance fired the event handler in the following example? I could set up separate event handlers, but in this case, I will have many maps, and would prefer to keep the handler to one function. Thanksvar mapExtentChange = map.on("extent-change", changeHandler);
var mapExtentChange = map2.on("extent-change", changeHandler);
function changeHandler(evt){
//if map1 fired then...
map1.extent = evt.extent;
//else
map2.extent = evt.extent;
