In ArcGIS 10.3, I had my shapefile list working in the script geoprocessing dialog window for the projection tool;
# Get the spatial reference
spatialRef = arcpy.Describe(template).spatialReference.name
# Loop through shapfiles in folder and reproject
for fc in fcList:
fcspatialRef = arcpy.Describe(fc).spatialReference.name
if fcspatialRef != spatialRef:
arcpy.Project_management(fc, outFolder + "\\" + fc, template)
# Print shapefile Project results
arcpy.AddMessage(fc)
# Return any errors
except:
arcpy.AddMessage(arcpy.GetMessages())
But when I add in copyFeatures_management because I want to copy the files which are already in the same projection and not reproject them, the dialog window changes and I lose my shapefile list in the geoprocessing dialog window;
for fc in fcList:
else:
arcpy.CopyFeatures_management(fc, outFolder + "\\" + fc)
# Return any errors
except:
Can anyone please assist?
