I have an issue with some netCDF data I have downloaded from the NCEP/NCAR reanalysis plots on the NOAA website (https://www.esrl.noaa.gov/psd/data/composites/day/). When imported into ArcMap, the data appears, but shows up blank through the central meridian for some reason (see attached image below).
I am using the WGS84 coordinate system, and the rest of the world shows up fine, but I am analysing meteorological parameters across the entire European continent, so the blank data through the central meridian is not something I can ignore unfortunately.
I am not sure why this is happening or how I can fix this. Any help would be greatly appreciated, thank you.
