Good Day,
One of the scripts i use is:
- import arcpy
- from arcpy import env
- env.workspace = r"C:\Temp\Test.gdb"
- listFCs = arcpy.ListFeatureClasses("*")
- for fc in listFCs:
- count1 = str(arcpy.GetCount_management(fc))
- if count1 == "0":
- arcpy.Delete_management(fc)
In arcgis pro this scripts is giving my this error
Start Time: zaterdag 9 december 2017 21:22:32
Running script DumpEmptyData...
Failed script DumpEmptyData...
File "F:\GIS_Data\Tools\Python Scripts\DeleteEmptyfields.py", line 21, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 16029, in GetCount
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 16026, in GetCount
retval = convertArcObjectToPythonObject(gp.GetCount_management(*gp_fixargs((in_rows,), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Rows: Dataset not_empty_feature_1 does not exist or is not supported
Failed to execute (GetCount).
Failed to execute (DumpEmptyData).
Failed at zaterdag 9 december 2017 21:22:33 (Elapsed Time: 0,66 seconds)
I now use the count tool to NOT copy features in the first place (this is even better) but it bugs my why it did not work (did not get a error in the analyse tool)
greetings Peter
