I need some help using the TraceDownstream tool off of the ArcGIS rest services. It works completely fine if I run it within ArcMap, but my goal is too implement it in a python tool for a project that I am doing. I can copy & paste the stand-alone script listed in the item description of the tool, but for some reason it still will not import successfully. I've attached the code below, and again..it is verbatim from the stand-alone script in the item description. I created a point feature class called "pourpt1" and placed it in the testdata geodatabase. #trace down stream
Best,
Casey
