I have several maps on ArcGIS Online that our field people use as for reference.
The maps have 30-40 layers. They have worked fine for years until recently.
When the user pinch zooms & pans, at some point the map will reopen to the default extent.
I have been removing layers to see if there was a 'culprit' layer, but no luck so far.
I made a new map with one layer, then added the others back in small groups, testing each time on the iPad.
The map worked. I kept adding layers until I had my original map. The issue returned.
I removed the last layer I added. Issue till there. I removed several more. Still there.
An ESRI support person suggested that "there might be some memory limitations on the iOS system side". Which kind of makes sense with what I am seeing. But why now, when they have worked fine for years? Same iPad. With current updates. Would an Apple update cause a memory leak somehow?
