So I'm new to working with promises, but I'm having trouble wrapping my head around these asynchronous requests. I am running a QueryTask within a result loop from a FindTask. I am outputting all results to an array, to display once everything finishes up. The issue I am experiencing comes with accessing the results. I can pull out the results from the FindTask with no problem, but when I perform an "execute().then()" statement for my query task, those results are not returned until the promise resolves. However, I would like to access those results sooner (e.g. as soon as that query task is executed). My question is, is there any way to execute a QueryTask without using Promises? Or is there a way to return results immediately within a promise?
My code is posted below for clarification. the goal is to perform a spatial query based off of the returned result of a FindTask, without displaying a map. Any help or tips are much appreciated!
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/tasks/QueryTask"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/support/Query"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/FindTask"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/support/FindParameters"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/_base/array"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>QueryTask<SPAN class="punctuation token">,</SPAN> Query<SPAN class="punctuation token">,</SPAN> FindTask<SPAN class="punctuation token">,</SPAN> FindParameters<SPAN class="punctuation token">,</SPAN> arrayUtils<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> loadingImg <SPAN class="operator token">=</SPAN> dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"loading"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Create a FindTask pointing to a map service</SPAN>
<SPAN class="keyword token">var</SPAN> find <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FindTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fgis2.co.frederick.va.us%2Farcgisweb%2Frest%2Fservices%2FFC_GIS%2FFCBase_TEST%2FMapServer" target="_blank">http://gis2.co.frederick.va.us/arcgisweb/rest/services/FC_GIS/FCBase_TEST/MapServer</A><SPAN>"</SPAN></SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Set parameters to only query the point layer by name</SPAN>
<SPAN class="keyword token">var</SPAN> params <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FindParameters</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
layerIds<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">6</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
searchFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"ADDRESS"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
returnGeometry<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
<SPAN class="comment token">// Query task REST endpoint for polygon layer to be queried.</SPAN>
<SPAN class="keyword token">var</SPAN> qt <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fgis2.co.frederick.va.us%2Farcgisweb%2Frest%2Fservices%2FFC_GIS%2FFCBase_TEST%2FMapServer%2F0" target="_blank">http://gis2.co.frederick.va.us/arcgisweb/rest/services/FC_GIS/FCBase_TEST/MapServer/0</A><SPAN>"</SPAN></SPAN>
resultsarray <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Executes on each button click</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">doFind</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Display loading gif to provide the user feedback on search progress</SPAN>
loadingImg<SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>visibility <SPAN class="operator token">=</SPAN> <SPAN class="string token">"visible"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Set the search text to the value of the input box</SPAN>
params<SPAN class="punctuation token">.</SPAN>searchText <SPAN class="operator token">=</SPAN> dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"inputAdr"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// The execute() performs a LIKE SQL query based on the provided text value</SPAN>
<SPAN class="comment token">// showResults() is called once the promise returned here resolves</SPAN>
<SPAN class="comment token">// find.execute(params).then(showResults, rejectedPromise);</SPAN>
find<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>doGeoQuery<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">otherwise</SPAN><SPAN class="punctuation token">(</SPAN>rejectedPromise<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">debugger</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">doGeoQuery</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// "response.results" is the data object containing fields and geometry from the found feature</SPAN>
<SPAN class="keyword token">var</SPAN> results <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">;</SPAN>
arrayUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>findResult<SPAN class="punctuation token">,</SPAN> i<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Get each value of the desired attributes</SPAN>
<SPAN class="keyword token">var</SPAN> geo <SPAN class="operator token">=</SPAN> findResult<SPAN class="punctuation token">.</SPAN>feature<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> adr <SPAN class="operator token">=</SPAN> findResult<SPAN class="punctuation token">.</SPAN>feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>ADDRESS<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> recnum <SPAN class="operator token">=</SPAN> findResult<SPAN class="punctuation token">.</SPAN>feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>RECNUM<SPAN class="punctuation token">;</SPAN>
resultsarray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>adr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
resultsarray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>recnum<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"geo"</SPAN><SPAN class="punctuation token">,</SPAN>geo<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"adr"</SPAN><SPAN class="punctuation token">,</SPAN>adr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"recnum"</SPAN><SPAN class="punctuation token">,</SPAN>recnum<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> spatialquery <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
spatialquery<SPAN class="punctuation token">.</SPAN>outFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"PIN"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"MLNAM"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
spatialquery<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="operator token">=</SPAN> geo<SPAN class="punctuation token">;</SPAN>
spatialquery<SPAN class="punctuation token">.</SPAN>spatialRelationship <SPAN class="operator token">=</SPAN> <SPAN class="string token">"intersects"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// execute QueryTask </SPAN>
qt<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>spatialquery<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>spatialresults<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"spatialresults.features"</SPAN><SPAN class="punctuation token">,</SPAN> spatialresults<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
resultsarray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>spatialresults<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>MLNAM<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
resultsarray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>spatialresults<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>PIN<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"resultsarrayloop"</SPAN><SPAN class="punctuation token">,</SPAN>resultsarray<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
resultsTable<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// If no results are returned from the task, notify the user</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>resultsarray<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">===</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
resultsTable<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">"<i>No results found</i>"</SPAN><SPAN class="punctuation token">;</SPAN>
loadingImg<SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>visibility <SPAN class="operator token">=</SPAN> <SPAN class="string token">"hidden"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//console.log("resutls",results);</SPAN>
<SPAN class="comment token">// Set up row for descriptive headers to display results</SPAN>
<SPAN class="keyword token">var</SPAN> topRow <SPAN class="operator token">=</SPAN> resultsTable<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertRow</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> cell1 <SPAN class="operator token">=</SPAN> topRow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertCell</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> cell2 <SPAN class="operator token">=</SPAN> topRow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertCell</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> cell3 <SPAN class="operator token">=</SPAN> topRow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertCell</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> cell4 <SPAN class="operator token">=</SPAN> topRow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertCell</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//var cell5 = topRow.insertCell(4);</SPAN>
cell1<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">"<b>Address</b>"</SPAN><SPAN class="punctuation token">;</SPAN>
cell2<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">"<b>Recnum</b>"</SPAN><SPAN class="punctuation token">;</SPAN>
cell3<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">"<b>MLNAM</b>"</SPAN><SPAN class="punctuation token">;</SPAN>
cell4<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">"<b>PIN</b>"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//cell5.innerHTML = "<b>geometry</b>";</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"resultsarray"</SPAN><SPAN class="punctuation token">,</SPAN>resultsarray<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Loop through each result in the response and add as a row in the table</SPAN>
<SPAN class="keyword token">var</SPAN> adr <SPAN class="operator token">=</SPAN> resultsarray<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> recnum <SPAN class="operator token">=</SPAN> resultsarray<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> nam <SPAN class="operator token">=</SPAN> resultsarray<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> pin <SPAN class="operator token">=</SPAN> resultsarray<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Add each resulting value to the table as a row</SPAN>
<SPAN class="keyword token">var</SPAN> row <SPAN class="operator token">=</SPAN> resultsTable<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertRow</SPAN><SPAN class="punctuation token">(</SPAN>i <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> cell1 <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertCell</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> cell2 <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertCell</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> cell3 <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertCell</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> cell4 <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">.</SPAN><SPAN class="token function">insertCell</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//var cell5 = row.insertCell(4);</SPAN>
cell1<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> adr<SPAN class="punctuation token">;</SPAN>
cell2<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> recnum<SPAN class="punctuation token">;</SPAN>
cell3<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> nam<SPAN class="punctuation token">;</SPAN>
cell4<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> pin<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//cell5.innerHTML = geo;</SPAN>
<SPAN class="keyword token">var</SPAN> resultsTable <SPAN class="operator token">=</SPAN> dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"tblAdr"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Executes each time the promise from find.execute() is rejected.</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">rejectedPromise</SPAN><SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Promise didn't resolve: "</SPAN><SPAN class="punctuation token">,</SPAN> err<SPAN class="punctuation token">.</SPAN>message<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Run doFind() when button is clicked</SPAN>
<SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"findBtn"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> doFind<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
