We are using ArcGIS Runtime .NET 10.2.6 and the legend-control in ArcGIS Runtime Toolkit for Windows Desktop.
We are trying to add a checkbox to each subLayer from a DynamicMapService to switch visibility. We've been able to add a checkbox defined in a LayerTemplate.
So far, we have (based on the runtime .NET sample "LegendsInTreeViewSample):
<esri:Legend x:Name="legend2" Layers="{Binding Converter={StaticResource enumerator}}" ShowOnlyVisibleLayers="False" >
<esri:Legend.LayerTemplate>
<DataTemplate>
<StackPanel Orientation="Horizontal">
<CheckBox Content="{Binding Label}" IsChecked="{Binding IsEnabled, Mode=TwoWay}"/>
</StackPanel>
</DataTemplate>
</esri:Legend.LayerTemplate>
</esri:Legend>
In line 5 the binding of the property "Label" works fine, it shows the layers lable.
Unfortunately it doesn't work with the property "IsEnabled": if one checkbox is cheked/unchecked, all other layers on the same level are also affected
Has anyone experienced similar behavior?
Is there a workaround to achieve the desired behavior? Fabian
