Adjusting properties on the SpatialReference class
Hi
I'm trying to adjust the SpatialReference using the SpatialReference class, but it doesn't seem to be working. In my example i'm trying to adjust the centralMeridian, but the final output still has the original value of -96.0.
Anybody has an idea how to make this work ?
Here is my example:
#!/usr/bin/env python
import arcpy, sys
Output_Spatial_Reference = "PROJCS['North_America_Lambert_Conformal_Conic',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-96.0],PARAMETER['Standard_Parallel_1',20.0],PARAMETER['Standard_Parallel_2',60.0],PARAMETER['Latitude_Of_Origin',40.0],UNIT['Meter',1.0]];-35214300 -28218500 10000;-100000 10000;-100000 10000;0.001;0.001;0.001;IsHighPrecision"
sr = arcpy.SpatialReference()
sr.loadFromString(Output_Spatial_Reference)
sr.centralMeridian = 10.0
result = sr.exportToString()
print "printing result:"
print result
