This sql works fine from pl/sql developer but fails when I try and do it with cx_Oracle.
Working fine....
<SPAN class="keyword token">call</SPAN> sde<SPAN class="punctuation token">.</SPAN>version_util<SPAN class="punctuation token">.</SPAN>set_current_version <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'ARCFM8.vtest'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">call</SPAN> sde<SPAN class="punctuation token">.</SPAN>version_user_ddl<SPAN class="punctuation token">.</SPAN>edit_version <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'ARCFM8.vtest'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">update</SPAN> arcfm8<SPAN class="punctuation token">.</SPAN>table_vw <SPAN class="keyword token">set</SPAN> REFERENCEDRAWING <SPAN class="operator token">=</SPAN> <SPAN class="string token">'my multiversion view update!!'</SPAN>
<SPAN class="keyword token">where</SPAN> OBJECTID <SPAN class="operator token">=</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">commit</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">call</SPAN> sde<SPAN class="punctuation token">.</SPAN>version_user_ddl<SPAN class="punctuation token">.</SPAN>edit_version <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'ARCFM8.vtest'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Failing on line 3...
with cx_Oracle.connect("arcfm8/xyz@xyz") as connection:
cursor = connection.cursor()
cursor.callproc("sde.version_util.set_current_version", ('ARCFM8.vtest'))
cursor.callproc("sde.version_user_ddl.edit_version", ('ARCFM8.vtest', 1))
cursor.execute(
"update arcfm8.table_vw set REFERENCEDRAWING = 'my SECOND multiversion view update!!!' where OBJECTID = 3")
cursor.callproc("sde.version_user_ddl.edit_version", ('ARCFM8.vtest', 2))cx_Oracle.DatabaseError: ORA-06550: line 1, column 7:
PLS-00306: wrong number or types of arguments in call to 'SET_CURRENT_VERSION'
PL/SQL: Statement ignored
