Hey,I am using the make feature layer command with a user defined feature class and field. The where statement is created with the field and value that the user defines. The problem is that the field is sometimes a number and sometimes a text value. So the quotes (or lack of them) in the where statement will crash the make feature layer command. I tried to use the cast or convert commands to convert the field to a string field so the where command will always have the same type of quotes. I am not able to get the convert or cast to work. Here are some samples of what I tried:
//string whereClause = "Cast(\"" + fieldname + "\" AS varchar) = '" + fieldval + "'";
//string whereClause = "\"Cast(" + fieldname + " AS varchar)\" = '" + fieldval + "'";
//string whereClause = "\"" + fieldname + "\" = '" + fieldval + "'";
//string whereClause = "\"Convert(varchar(500), '" + fieldname + "')\" = '" + fieldval + "'";
//string whereClause = "\"Convert(varchar, '" + fieldname + "')\" = '" + fieldval + "'";
//string whereClause = "Convert(varchar, \"" + fieldname + "\") = '" + fieldval + "'";
string whereClause = "Convert(varchar, " + fieldname + ") = '" + fieldval + "'";
Does anybody know how to use the convert or cast command, or a better way to accomplish this?Thanks, Chris
