Hi all,
I have a FC in an SDE with Fields: ID & Version.
These are populated like this:
ID "A", Version "1"
ID "A", Version "2"
ID "B", Version "1"
ID "B", Version "2"
etc..
so when the ID object changes we create a new shape with a new Version number, but keep the old shape for historic purposes.
I am doing a join on another table but only want to perform the join on a subset of the original FC, grabbing the latest "Version" of the ID.
For the life of me I cannot seem to be able to select these records.
This will be a python script.
I was thinking of using the arcpy.MakeFeatureLayer_management with an expression and/or arcpy.SelectLayerByAttribute_management function with an expression to form my subset before I join to another table.
"Version" = (SELECT MAX("Version") from FC) - does not seem to work. I also tried a "group by" and got a sql error.
We are using SQL server and ArcGIS 10.2
Even in ArcMap I cannot seem to be able to select the latest version of the ID....I am guessing I don't have the syntax correct.
any help would be appreciated.
thanks
