Hi,I am trying to convert UTM coordinates in zone 13 to lat/long using a geometry service. I followed the sample I found in the Silverlight samples web site, but I am getting the following exception when executing:"Exception Details: System.Web.HttpException: No Content"And Here is the Stack trace:[HttpException (0x80004005): No Content] ESRI.ArcGIS.WebServices.BaseServiceHandler.ReadStringRequest(HttpRequest request) +105 ESRI.ArcGIS.WebServices.CatalogHandler.HandleRequest(HttpContext context) +28 ESRI.ArcGIS.WebServices.CatalogHandler.QueryService(HttpContext ctx) +45Here is the request that got sent (NOTE: I have replaced the server name):
http://myserver.the.domain/ArcGIS/services/Geometry/GeometryServer/project?inSR=26913&outSR=4617&geometries=555776,6651833&f=json&
Here is the code that generated the request (NOTE: I have replaced the server name):
geometryService = new GeometryService("http://myserver.the.domain/ArcGIS/services/Geometry/GeometryServer");
geometryService.ProjectCompleted += geometryService_ProjectCompleted;
geometryService.Failed += geometryService_Failed;
double x = double.NaN;
double y = double.NaN;
double.TryParse(tbUlEasting.Text, out x);
double.TryParse(tbUlNorthing.Text, out y);
if (double.IsNaN(x) || double.IsNaN(y))
MessageBox.Show("Enter valid UL coordinate values");
return;
MapPoint ulPoint = new MapPoint(x, y, new SpatialReference(26913));
geometryService.ProjectAsync(new List<Graphic> { new Graphic() { Geometry = ulPoint } }, Map.SpatialReference, ulPoint);
Can anyone help?Thanks,Paul
