I have a table that i was able to publish in a map service and query it to populate a datagrid in my application. I need to allow users to edit the data from this table using the datagrid, but have been unable to figure out how to do this.I did use an 'itemFileWriteStore' to populate the grid with the queried records from the table. Here is the html for the grid.[HTML] <table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'" style="margin-top: 30px; height: 168px;"> <thead> <tr> <th field="GenSurvID" >General Survey ID</th> <th field="SurveyorID" >Surveyor ID</th> <th field="SpecificDate" >Specific Date</th> <th field="Book" >Book</th> <th field="PageNum" >Page Number</th> <th field="DocLink" formatter="makeLink" >Document Link</th> <th field="SurveyNum" >Survey Number</th> <th field="Section" >Section</th> <th field="Township" >Township</th> <th field="Range" >Range</th> <th field="EstimatedDate" >Estimated Date</th> <th field="CntyRemarks" width="100%">County Remarks</th> </tr> </thead> </table>[/HTML]here is the code that populates the grid...function showResults(selectedFeatures) { var results = selectedFeatures.features; if (results.length != 0) { //create array of attributes var items = dojo.map(results, function (result) { return result.attributes; }); //Create data object to be used in store var data = { identifier: "GenSurvID", //This field needs to have unique values items: items }; //Create data store and bind to grid. store = new dojo.data.ItemFileWriteStore({ data: data }); var grid = dijit.byId('grid'); grid.setStore(store); grid.editable = true; } else { divNoRecords.style.display = 'block'; } if (divToggleDetail.className == 'divToggleDetailExpand') { AnimateDetailsView() } HideLoadingMessage2(); }Any help would be greatly appreciated.Thanks,Mark
