For the life of me I cannot get a where clause to work in a cursor (search or update):
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SampleDate'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'SampleID'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'OBJECTID'</SPAN><SPAN class="punctuation token">]</SPAN>
where <SPAN class="operator token">=</SPAN> <SPAN class="string token">'SampleDate is null'</SPAN> <SPAN class="comment token"># do where clauses really work in a cursor? not for me.</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN>fields<SPAN class="punctuation token">,</SPAN>where<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
s_date <SPAN class="operator token">=</SPAN> str<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">' '</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
mnth <SPAN class="operator token">=</SPAN> s_date<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'-'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
day <SPAN class="operator token">=</SPAN> s_date<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'-'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN>
yr <SPAN class="operator token">=</SPAN> s_date<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'-'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
timestamp<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
newdate <SPAN class="operator token">=</SPAN> <SPAN class="string token">'{}{}{}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>yr<SPAN class="punctuation token">,</SPAN>mnth<SPAN class="punctuation token">,</SPAN>day<SPAN class="punctuation token">)</SPAN>
pre <SPAN class="operator token">=</SPAN> <SPAN class="string token">'FP'</SPAN>
exp <SPAN class="operator token">=</SPAN> <SPAN class="string token">"'{} {} {}'"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>pre<SPAN class="punctuation token">,</SPAN>newdate<SPAN class="punctuation token">,</SPAN>new_time<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">'{} {} {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>exp<SPAN class="punctuation token">,</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>When I include the where clause as shown I get no returns with my print. I've capitalized IS NULL, same result; I have used the same 'where' in an ArcMap interactive selection just fine. I gotta be missing something slight....
