I posted earlier about UpdateCursor not working, but since then I have narrowed the problem down to MakeFeatureLayer. What I am trying to do is loop over features in a point class and isolate each one into its own layer using a where statement, and then delete the layer before the next iteration. (This is just for diagnostic purposes - not meant to do anything productive.) The problem is that when I give MakeFeatureLayer a where statement, it will only run twice and then stop without any errors or messages.This is my code :# Make feature layer of all points arcpy.MakeFeatureLayer_management("pyServiceConnection", "servLyr") # Make search cursor with layer rows = arcpy.SearchCursor("servLyr") # Loop over points for row in rows: # Make feature layer with the current point only where = "\"OBJECTID\" = " + str(row.OBJECTID) arcpy.MakeFeatureLayer_management("servLyr", "curServLyr", where) # Delete feature layer arcpy.Delete_management("curServLyr")
Interestingly, if I leave out the where statement the code will run to completion. I have tried using other where statements such as "1=1" but all of them caused the same fail after the second run. I am totally stumped by this - can anyone think of what could be going on here?
