I would like to get going with the SDK for Java and Eclipse.
Installed is ArcGIS 10.3, the DeveloperKit 10.3 for Java and Eclipse Luna.
The Eclipse plugin was installed as well, where I got that the ArcObjects Palette will not be installed because I probably do not have the Visual Editor project installed. That's correct, since the project is discontinued and replaced by the WindowBuilder project (not supported by ESRI). But ArcObjects installed.
My JRE is of version 1.8.0_40 and I have it as 32bit version installed. I am at a Windows machine and added the path of Desktop10.3\bin and jdk1.8.0_40\bin to my system path variable.
Now, if I create a new ArcObjects project in Eclipse, leave all the default settings in the wizard and click finish, then I am facing the following errors:
Exception in thread "main" java.lang.RuntimeException: AutomationException: 0x80040112 -
at com.esri.arcgis.interop.Ocx.<init>(Unknown Source)
at com.esri.arcgis.controls.ToolbarControl.<init>(Unknown Source)
at com.esri.arcgis.beans.toolbar.ToolbarBean.a(Unknown Source)
at com.esri.arcgis.beans.toolbar.ToolbarBean.<init>(Unknown Source)
at BasicViewer.getToolbarBean(BasicViewer.java:146)
at BasicViewer.getJContentPane(BasicViewer.java:110)
at BasicViewer.initialize(BasicViewer.java:87)
at BasicViewer.<init>(BasicViewer.java:77)
at BasicViewer.main(BasicViewer.java:134)
Caused by: AutomationException: 0x80040112 -
... 9 more
That's something I don't understand. The license I am using is an academic license with quite some extensions licensed as well. I went into my ArcGIS Administrator to see if I have to do something there but there is nothing to do. What am I missing?
Thanks for your help,
Thomas
