I need some help with arcpy.da.SearchCursor and dictionary.I currently have the old Search.Cursor here # init rowW and rowR
curR = arcpy.SearchCursor(fcOutput)
join_dict = dict([(r.JOIN_FID,[r.getValue(f) for f in add_fields]) for r in curR])
del curR
I would like to use the new arcpy.da.SearchCursor with a dictionary.I am trying to put it together with the following,# init rowW and rowR
with arcpy.da.SearchCursor(fcOutput,fields) as cursor:
for row in cursor:
cursor = dict([(r.JOIN_FID,[r.getValue(f) for f in arcpy.da.SearchCursor (fcTarget,add_fields)])
del cursor
But no luck i would really appreciate some help please.my fully code,
import arcpy
import pythonaddins
import os
import time
from arcpy import env
class Timer:
def __enter__(self):
self.start = time.clock()
return self
def __exit__(self, *args):
self.end = time.clock()
self.interval = self.end - self.start
class Add_points(object):
"""Implementation for AddPoints_addin.Add_points (Tool)"""
def __init__(self):
self.enabled = True
self.cursor = 3 # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.
def onMouseDownMap(self, x, y, button, shift):
fc = "TonyTwoWay.DBO.TT"
workspace = r"C:\Users\talmeida\AppData\Roaming\ESRI\Desktop10.1\ArcCatalog\Connection to dsd15_sqlexpress.sde"
#arcpy.ChangeVersion_management('TonyTwoWay.DBO.TT','TRANSACTIONAL','dbo.DEFAULT', "")
# Start an edit session. Must provide the worksapce.
edit = arcpy.da.Editor(workspace)
# Edit session is started without an undo/redo stack for versioned data
# (for second argument, use False for unversioned data)
edit.startEditing(True)
# Start an edit operation
edit.startOperation()
CC_list = []
with arcpy.da.SearchCursor(fc, ["AddressID"]) as cursor:
for row in cursor:
try:
if "CC" in row[0]:
CC_list.append(int(row[0].strip("CC")))
except TypeError:
pass
del cursor
t = Timer()
with t:
CC_list.sort()
AddressID = CC_list[-1] + 1
AddressID = 'CC' + str(AddressID)
row_values = [(x, y, (x, y), AddressID)]
cursor = arcpy.da.InsertCursor(fc, ["X_Coord", "Y_Coord", "SHAPE@XY", "ADDRESSID"])
for row in row_values:
cursor.insertRow(row)
del cursor
# Stop the edit operation.
edit.stopOperation()
# Stop the edit session and save the changes
edit.stopEditing(True)
timetest = "completed in %.02f secs." % (t.interval)
print timetest
fcTarget = "TonyTwoWay.DBO.TT"
fcJoin = "testParcelsAdmit"
add_fields = ["ACCOUNT","SiteNum","OwnerName","SiteAddres","SiteNumSfx","SiteStreet","predir","StreetType","SubName"]
# fix args
if not isinstance(add_fields, list):
# from script tool
add_fields = add_fields.split(';')
# do not need this scratch file
fcOutput = r'in_memory\temp_join'
arcpy.SpatialJoin_analysis(fcJoin, fcTarget,fcOutput, 'JOIN_ONE_TO_MANY')
# grab oid field from points
oid_t = arcpy.Describe(fcTarget).OIDFieldName
for row in cursor:
del cursor
# Now update the new target
curW = arcpy.UpdateCursor(fcTarget)
for row in curW:
t_oid = row.getValue(oid_t)
if t_oid in join_dict:
for f in add_fields:
row.setValue(f, join_dict[t_oid][add_fields.index(f)])
curW.updateRow(row)
del row, curW
arcpy.AddMessage('Updated all records sucussefully')
pass
