Dear All
I am working now to develop application by using Arcgis Engine 10.1 / Arcobject (Java) , i have connect to personal Geodabase (Mdb) and i retrieve fields name layer name , fields properties (Geometry , type...) but when i try to retrieve information for the values (attribute value) i got null value .... i need your help to get the value in the fields ?
for example if i have (USA.mdb) personal geodatabase , layer name is : country , (fields : county name , country name , area) ....
what i need exactly to retrieve the county value from the county field (California , Colorado... ...)
the below the code what i use it ....
and what is the different if i read the feature through (MXD file) or direct connect to MDB (personal Geo-database) the code will change or what i need you clarification please ....
IFeatureClass featureClass = featureLayer.getFeatureClass();
System.out.println(">>>+>>>>>"+featureClass.getAliasName());
// System.out.println(">>>+>>>>>"+featureClass.getFeatureClassID());
// System.out.println(">>>+>>>>>"+featureClass.getFeatureType());
IFields fields = featureClass.getFields();
System.out.print("+++++++++count " +fields.getFieldCount());
// for (int i =0 ; i< fields.getFieldCount() ;i++){
// System.out.println(fields.getField(i).getName() + " - " + fields.getField(i).getDefaultValue());
for (int index = 0; index < fields.getFieldCount(); index++) {
//Get the field at the specified index
Field field = (Field) fields.getField(index);
if (field == null) {
System.out.println("Field is null ");
continue;
//Print out some metadata information
System.out.println("\tPhysical Name : " + field.getName());
System.out.println("\tAlias Name : " + field.getAliasName());
System.out.println("\tType : " + getFieldTypeDescription(field.getType()));
System.out.println("\tLength : " + field.getLength());
System.out.println("\tPrecision : " + field.getPrecision());
System.out.println("\tEditable : " + field.isEditable());
//Default Value
Object defaultValue = field.getDefaultValue();
if (defaultValue == null) {
System.out.println("\tDefault Value : <Unspecified>");
else {
System.out.println("\tDefault Value : " + defaultValue);
System.out.println();
