For some reason this query works on FGDB but not SDE geodatabases. Is that by design? When I use select by attributes and type this query:
EXTRACT(YEAR FROM MyDateField) = 2015
This will work on a file geodatabase. When I try the same query with an SDE geodatabase, I get the error:
"There was an error executing the query. Invalid SQL syntax [[Microsoft][ODBC Driver 13 for SQL Server][SQL Server] Incorrect syntax near the keyword 'FROM'.][mydata.dbo.database]."
I have tried rewriting the query in these ways but all come back with the same error:
EXTRACT(YEAR FROM "MyDateField") = 2015
EXTRACT(YEAR FROM MyDateField) = '2015'
EXTRACT(YEAR FROM [MyDateField]) = 2015
The last thing I tried was the DatePart function. This appears to work on SDE geodatabases:
DatePart("yyyy", MyDateField) = 2015
I am confused as to why this one works but not the EXTRACT one, especially because DatePart looks like it's meant for personal geodatabases: How To: Search for specific parts of a date stored in a Date-Time field
Additionally, when building a query to use as a filter in Javascript API, the EXTRACT(YEAR FROM "MyDateField") = 2015 works on the SDE data and the DatePart does not. You'd think that one of these types of queries would work in all cases...frustrating.
