In Pro you can create and publish your services. You can then start a new map and design your Web Map by brining in the services (in our case from Portal). You can then share the web map to your desired group and location direct from Pro
However, if you need to make changes to that Web Map how can you make those changes take place in the Web Map, from Pro. You can share it again, but you need to delete the existing one first or change the name.
Is there a way around this?
