I am trying to reset a form for data entry once the form displays to ensure there are no previous values but I get the following error when I try reset:
Uncaught TypeError: document.getElementById(...).reset is not a function
The code I am using is:
document.getElementById("attributesSignModal").reset();A common mistake is having an element named reset, but I don't have that issue on my application.
Here is the form that I can not reset:
<!-- Attributes Sign Modal Begin -->
<div id="attributesSignModal" class="modal fade" style="display: none;" aria-hidden="true">
<!-- Modal Dialog Begin -->
<div class="modal-dialog">
<div class="modal-content">
<div class="modal-header">
<button type="button" class="close" data-dismiss="modal" aria-hidden="true">Ã</button>
<h4 class="modal-title">Add/Edit Sign</h4>
</div>
<div class="modal-body">
<!-- Installed Begin -->
<div class="form-group">
<label for="installed">Installed</label>
<input type="date" class="form-control" name="installed" id="installed" />
</div>
<!-- Installed End -->
<!-- Sign ID Begin -->
<label for="signId">Sign ID</label>
<input type="number" class="form-control" placeholder="Sign ID" name="signId" id="signId" />
</div>
<!-- Sign ID End -->
<!-- Facing Begin -->
<label for="facing">Facing</label>
<input type="text" class="form-control" placeholder="Facing" name="facing" id="facing" />
</div>
<!-- Facing End -->
<!-- Visibility Begin -->
<label for="visibility">Visibility</label>
<select id="visibility" class="form-control" name="visibility">
</select>
</div>
<!-- Visibility End -->
<!-- Condition Begin -->
<label for="condition">Condition</label>
<select id="condition" class="form-control" name="visibility">
</select>
</div>
<!-- Condition End -->
<!-- Support ID Begin -->
<label for="supportId">Support ID</label>
<input type="number" class="form-control" name="supportId" id="supportId" />
</div>
<!-- Support ID End -->
<!-- Text Begin -->
<label for="text">Text</label>
<input type="text" class="form-control" name="text" id="text" />
</div>
<!-- Text End -->
<!-- Color 1 Begin -->
<label for="color1">Color 1</label>
<select id="color1" class="form-control" name="color1" required>
</select>
</div>
<!-- Color 1 End -->
<!-- Delineator Begin -->
<label for="delineator">Delineator</label>
<select id="delineator" class="form-control" name="delineator">
</select>
</div>
<!-- Delineator End -->
<!-- Illum Begin -->
<label for="illum">Illum</label>
<select id="illum" class="form-control" name="illum">
</select>
</div>
<!-- Illum End-->
<!-- Offset Begin -->
<label for="offset">Offset</label>
<input type="text" class="form-control" name="offset" id="offset" />
</div>
<!-- Offset Ends -->
<!-- Mountht Begin -->
<label for="mountht">MOUNTHT</label>
<input type="text" class="form-control" name="mountht" id="mountht"/>
</div>
<!-- Mountht End -->
<!-- Backing Begin -->
<label for="backing">Backing</label>
<select id="backing" class="form-control" name="backing">
</select>
</div>
<!-- Backing End -->
<!-- Width Begin -->
<label for="width">Width</label>
<input type="text" class="form-control" name="width" id="width" />
</div>
<!-- Width End -->
<!-- Height Begin -->
<label for="height">Height</label>
<input type="text" class="form-control" name="height" id="height"/>
</div>
<!-- Height End -->
<!-- Txt Size Begin -->
<label for="txtSize">Text Size</label>
<input type="text" class="form-control" name="txtSize" id="txtSize"/>
</div>
<!-- Txt Size End -->
<!-- Num Size Begin -->
<label for="numSize">Numsize</label>
<input type="text" class="form-control" name="numSize" id="numSize"/>
</div>
<!-- Num Size End -->
<!-- Comments Begin -->
<label for="comments">Comments</label>
<input type="text" class="form-control" name="comments" id="comments"/>
</div>
<!-- Comments End -->
<!-- Two Sided Begin -->
<label for="twoSided">Two Sided</label>
<input type="text" class="form-control" name="twoSided" id="twoSided" />
</div>
<!-- Two Sided End -->
<!-- Attach Type Begin -->
<label for="attachType">Attach Type</label>
<select id="attachType" class="form-control" name="attachType">
</select>
</div>
<!-- Attach Type End -->
<!-- Attach Num Begin -->
<label for="attachNum">Attach Num</label>
<input type="text" class="form-control" name="attachNum" id="attachNum"/>
</div>
<!-- Attach Num End -->
<!-- Attach Loc Begin -->
<label for="attachLoc">Attach Loc</label>
<select id="attachLoc" class="form-control" name="attachLoc">
</select>
</div>
<!-- Attach Loc End -->
<!-- siteObs Begin -->
<label for="siteObs">Siteobs</label>
<select id="siteObs" class="form-control" name="siteObs">
</select>
</div>
<!-- siteObs End -->
<!-- Sign Shape Begin -->
<label for="signShape">Sign Shape</label>
<select id="signShape" class="form-control" name="signShape">
</select>
</div>
<!-- Sign Shape End -->
<!-- Color 2 Begin -->
<label for="color2">Color 2</label>
<select id="color2" class="form-control" name="color2">
</select>
</div>
<!-- Color 2 End -->
<!-- Mutcd Begin -->
<label for="mutcd">MUTCD</label>
<select id="mutcd" class="form-control" name="mutcd">
</select>
</div>
<!-- Mutcd End -->
<button class="btn btn-success">Submit</button>
<button class="btn btn-default">Cancel</button>
<button id="btnPrevious" class="btn navButton" style="visibility:hidden">Previous</button>
<button id="btnNext" class="btn navButton" style="visibility:hidden">Next</button>
</div>
</div>
</div>
<!-- Modal Dialog End -->
</div>
<!-- Attributes Sign Modal End -->
