I have published a feature service which has both spatial layers and non-spatial tables.
Next, I want to generate a runtime .geodatabase using GenerateGeodatabaseJob::generateGeodatabase(parameters, fileLocation).
The parameters are generated with GeodatabaseSyncTask::createDefaultGenerateGeodatabaseParameters().
The documentation of this method says
But also
Related tables and layers are not included.
I guess this included non-spatial tables.
To fix this, I set the GenerateLayerOption.setUseGeometry to False, and add a whereClause to select everything ("1=1").
But still, I get the following error :
Unable to create replica. Please check your parameters." : "Exporting data for layer 10 failed."
First of all, is it possible to download non-spatial tables with these methods ?
And if yes, which settings do I need to change ?
All suggestions are welcome.
PS : There is an "ugly" workaround, but I like to avoid it : convert all non-spatial tables to feature tables, by adding a shape field with 1 point
