Hello,I've created some code that'll zoom to a feature queried from an ArcGIS Server Map Service, however now I want to flash the feature's geometry on the screen. I've grabbed the FlashGeometry snippet, http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#/Flash_Geometry_Snippet/004900000075000000/however nothing happens when I get to that portion of my code. I'm not sure what I'm missing, any suggestions would be appreciated.{
IGISServerConnection pGISServCon = new GISServerConnection();
pGISServCon.Connect("MyServer");
IServerObjectManager pSOM = pGISServCon.ServerObjectManager;
IServerContext pServerContext = pSOM.CreateServerContext("MyMapService", "MapServer");
IMapServer pMapServer = pServerContext.ServerObject as IMapServer;
IMapServerObjects pMapServerObjs = pMapServer as IMapServerObjects;
IMap pMap = pMapServerObjs.get_Map(pMapServer.DefaultMapName);
ILayer pFLayer = pMap.get_Layer(zoomMapServID) as ILayer;
IFeatureLayer pFeatlayer = pFLayer as IFeatureLayer;
IFeatureClass pFeatureClass = pFeatlayer.FeatureClass;
IQueryFilter pQfilt = new QueryFilterClass();
pQfilt.WhereClause = zoomColumn + " = '" + textBox1.Text + "'";
IFeatureCursor pFC = pFeatureClass.Search(pQfilt, false);
IFeature pFeat = pFC.NextFeature(); // all queries will return only 1 feature
IGeometry pGeom = pFeat.ShapeCopy as IGeometry;
IApplication pApp = ArcMap.Application;
IMxDocument pMxd = ArcMap.Document;
// Get the focus map
IMap map = pMxd.FocusMap;
// Cast from IMap to IActiveView
IActiveView pActiveview = (IActiveView)map;
IEnvelope pEnv = new EnvelopeClass();
//Set envelope to the geometry collection from the property below
pEnv = pGeom.Envelope;
//Create a new envelope to pass the values to from the geometry
IEnvelope envelope = new EnvelopeClass();
envelope.XMax = pEnv.Envelope.XMax;
envelope.YMax = pEnv.Envelope.YMax;
envelope.XMin = pEnv.Envelope.XMin;
envelope.YMin = pEnv.Envelope.YMin;
envelope.Expand(150, 150, false);
pActiveview.Extent = envelope;
pActiveview.Refresh();
pActiveview.ScreenDisplay.UpdateWindow();
//Setup parameters for FlashGeometry method
IRgbColor rgbColor = new RgbColorClass();
//Color Properties
rgbColor.Red = 133;
rgbColor.Green = 135;
rgbColor.Blue = 43;
IDisplay pDisplay = pActiveview.ScreenDisplay;
FlashGeometry(pGeom, rgbColor, pDisplay, 300);
} Flash Geometry Code, I removed the case statements for all other geometries other than polygon to shorten the code block.public void FlashGeometry(ESRI.ArcGIS.Geometry.IGeometry geometry, ESRI.ArcGIS.Display.IRgbColor color, ESRI.ArcGIS.Display.IDisplay display, System.Int32 delay)
if (geometry == null || color == null || display == null)
return;
display.StartDrawing(display.hDC, (System.Int16)ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache); // Explicit Cast
switch (geometry.GeometryType)
case ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolygon:
//Set the flash geometry's symbol.
ESRI.ArcGIS.Display.ISimpleFillSymbol simpleFillSymbol = new ESRI.ArcGIS.Display.SimpleFillSymbolClass();
simpleFillSymbol.Color = color;
ESRI.ArcGIS.Display.ISymbol symbol = simpleFillSymbol as ESRI.ArcGIS.Display.ISymbol; // Dynamic Cast
symbol.ROP2 = ESRI.ArcGIS.Display.esriRasterOpCode.esriROPNotXOrPen;
//Flash the input polygon geometry.
display.SetSymbol(symbol);
display.DrawPolygon(geometry);
System.Threading.Thread.Sleep(delay);
break;
display.FinishDrawing();
