Hi
I'm having trouble with replaceDataSource in a script I've written. The purpose of the script is to iterate through multiple mxds in a directory and replace the data source of certain layers. It works for the most part, except for layers which I'm replacing with a SDE feature class.
The replaceDataSource section of the code is as follows:
for dirName, subdirList, fileList in os.walk(source_dir):
dest = destPath + dirName.replace(source_dir, '\\')
for fname in fileList:
if fname.endswith(".mxd")
try:
mxd = arcpy.mapping.MapDocument(dirName + "\\" + fname)
for lyr in arcpy.mapping.ListLayers(mxd):
if lyr.supports("DATASOURCE"):
if "\GIS Data\Arc Layers\Example.shp" in lyr.dataSource:
newPath = r"Database Connections\SDEConnection.sde"
newWS = "SDE_WORKSPACE"
newSource = "Example"
replace = True
if replace == True:
try:
print "Replacing data source of " + lyr.name
lyr.replaceDataSource(newPath,newWS, newSource)
except Exception, e:
print e
The Exception provided the rather unhelpful message "Layer: Unexpected Error". So I then tried setting the optional "validate" parameter to false and discovered it was doing something quite strange.
The data source of the layer seems to get set to the SDE connection file on a user's C drive (i.e. C:\Users\<username>\AppData\Roaming\ESRI\Desktop10.3\ArcCatalog\SDEConnection.sde) rather than linking directly to instance of the SDE. The user in question isn't even me, I'm assuming it is whoever added the layer to the project in the first place.
What's even more strange is that it successfully changes the data source of all appropriate layers if I just run the script on a single mxd. However when run on a directory with multiple mxds it is only successful the first time but then fails as above the next time it detects a layer to be changed.
I did see this thread, replaceDataSource connecting to SDE Instance, in which the OP seemed to have the same problem amongst others, but this particular issue didn't seem to be resolved by the end of it.
