Hi
I'm using Arcpy to "downgrade" a lot of mxd-files from 10.3 to 10.1 - using an ArcMap 10.3 version.
This is actually working very fine! The mxd's can open - as they should - in ArcMap 10.1/10.2!
The problem is that ArcPy can't read the files anymore - only after the files are opened - and saved - in ArcMap 10.1/10.2.
So... it appears that some kind of file corruption occures during the "downgrading"!
Any ideas to a solution to this?
The code I'm using:
mxd = arcpy.mapping.MapDocument(mxdInFile)
mxd.saveACopy(mxdOutFile,"10.1")
