I would like do the same thing to multiple Giz and Tarfiles. I already replaced "zipfile" for "tarfile" at the script, but It doesn't works with Python 2.7.1 at ArcMap 10.1 (but will be good which It works with newer ArcMap)
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="keyword token">import</SPAN> tarfile<SPAN class="punctuation token">,</SPAN>fnmatch<SPAN class="punctuation token">,</SPAN>os
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> rootPath <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\Teste_Auto_Unzip"</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> pattern <SPAN class="operator token">=</SPAN> <SPAN class="string token">'*.tar.gz'</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">for</SPAN> root<SPAN class="punctuation token">,</SPAN> dirs<SPAN class="punctuation token">,</SPAN> files <SPAN class="keyword token">in</SPAN> os<SPAN class="punctuation token">.</SPAN>walk<SPAN class="punctuation token">(</SPAN>rootPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">for</SPAN> filename <SPAN class="keyword token">in</SPAN> fnmatch<SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">(</SPAN>files<SPAN class="punctuation token">,</SPAN> pattern<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>root<SPAN class="punctuation token">,</SPAN> filename<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> tarfile<SPAN class="punctuation token">.</SPAN>TarFile<SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>root<SPAN class="punctuation token">,</SPAN> filename<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>extractall<SPAN class="punctuation token">(</SPAN>
os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>root<SPAN class="punctuation token">,</SPAN> filename<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"."</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
C<SPAN class="punctuation token">:</SPAN>\Teste_Auto_Unzip\LC82270692015242LGN00<SPAN class="punctuation token">.</SPAN>tar<SPAN class="punctuation token">.</SPAN>gz
Runtime error
Traceback <SPAN class="punctuation token">(</SPAN>most recent call last<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
File <SPAN class="string token">"<string>"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">7</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN>
File <SPAN class="string token">"C:\Python27\ArcGIS10.4\Lib\tarfile.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">1581</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> __init__
self<SPAN class="punctuation token">.</SPAN>firstmember <SPAN class="operator token">=</SPAN> self<SPAN class="punctuation token">.</SPAN>next<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
File <SPAN class="string token">"C:\Python27\ArcGIS10.4\Lib\tarfile.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">2356</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> next
<SPAN class="keyword token">raise</SPAN> ReadError<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
ReadError<SPAN class="punctuation token">:</SPAN> invalid header<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks in advance!
