Hi all,
I want to clear graphics and close popup on the close() button of the popup. I am using the watch method and it works great.
The issue I have with this method is that when I click to start the event listener, I want the function to clear all popups in the map previously opened by other functions.
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#clicking"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">click</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">close</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Since the watch event removes layers when view.popup.visible === false
<SPAN class="comment token">// Watch view's stationary property for becoming true.</SPAN>
watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">whenFalse</SPAN><SPAN class="punctuation token">(</SPAN>view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"visible"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>visible<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Get the new center of the view only when view is stationary.</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>visible<SPAN class="punctuation token">)</SPAN>
view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
layerbuffer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I can only add the layers once the popup is opened.
onclickhandler <SPAN class="operator token">=</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> visible1 <SPAN class="operator token">=</SPAN> view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN>visible<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#viewDiv'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">css</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'cursor'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'pointer'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
geombuffer <SPAN class="operator token">=</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
x<SPAN class="punctuation token">:</SPAN> event<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN>
y<SPAN class="punctuation token">:</SPAN> event<SPAN class="punctuation token">.</SPAN>y
pointGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> geombuffer<SPAN class="punctuation token">,</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> symboltoclone
<SPAN class="keyword token">var</SPAN> buffer <SPAN class="operator token">=</SPAN> geometryEngine<SPAN class="punctuation token">.</SPAN><SPAN class="token function">geodesicBuffer</SPAN><SPAN class="punctuation token">(</SPAN>geombuffer<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"feet"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> graphicbuffer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> buffer<SPAN class="punctuation token">,</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> fillSymbol
layerbuffer<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphicbuffer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>pointGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Set up query for geom</SPAN>
<SPAN class="keyword token">var</SPAN> queryTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> nitratequeryurl
<SPAN class="comment token">//Query to return California geometry</SPAN>
<SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Set the query</SPAN>
query<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="operator token">=</SPAN> buffer<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// the point location of the pointer</SPAN>
query<SPAN class="punctuation token">.</SPAN>outFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"OBJECTID "</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">//return geometry</SPAN>
query<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Intersects</SPAN>
query<SPAN class="punctuation token">.</SPAN>spatialRelationship <SPAN class="operator token">=</SPAN> <SPAN class="string token">"intersects"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Execute the query</SPAN>
queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">executeForCount</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">open</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Search Results"</SPAN><SPAN class="punctuation token">,</SPAN>
location<SPAN class="punctuation token">:</SPAN> geombuffer<SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"<br><center>Number of nitrate-impacted wells within 2000 feet of:<br><br><center>"</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"<center>"</SPAN> <SPAN class="operator token">+</SPAN> geombuffer<SPAN class="punctuation token">.</SPAN>latitude<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toFixed</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"N  "</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">","</SPAN> <SPAN class="operator token">+</SPAN> Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">abs</SPAN><SPAN class="punctuation token">(</SPAN>geombuffer<SPAN class="punctuation token">.</SPAN>longitude<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toFixed</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"W</center><br>"</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"<center><b>"</SPAN> <SPAN class="operator token">+</SPAN> response <SPAN class="operator token">+</SPAN> <SPAN class="string token">" Wells</b><br><center><br><i>Drag marker to update location</i></center>"</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">goTo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
target<SPAN class="punctuation token">:</SPAN> pointGraphic<SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">15</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Is there a way to clear graphics only if you click on the "close" button of the popup instead of the watch?
