Hello,I'm a python and arcpy beginner. I have a few simple scripts I'm working on for practice, but I'm having trouble with this one.Purpose = Create a 200 ft buffer around a user selected feature. Issue = I would like the 'output feature class' to default to a certain file path. I attempted to do this using arcpy.env.workspace. However, the default path keeps pointing to my C:\....Documents\ArcGIS\Default.gdbI've looked at some other examples and cannot figure out what I am doing wrong. I'd appreciate any help. Thanks.import arcpy
from arcpy import env
import os
# Set the geoprocessing environment
env.workspace = r"J:\Work\Projects\Case Change Maps\Python\Temp"
env.overwriteOutput = True
# Get Parameters from the user
DataToBuffer = arcpy.GetParameterAsText(0)
if DataToBuffer == '#' or not DataToBuffer:
DataToBuffer = "BASE.BASEMAP" # provide a default value if unspecified
BufferName = arcpy.GetParameterAsText(1)
if BufferName == '#' or not BufferName:
BufferName = "BUFF.shp" # provide a default value if unspecified
# Process
# Buffer the basemap selection
arcpy.Buffer_analysis(DataToBuffer, BufferName, "200 Feet", "FULL", "ROUND", "NONE", "")
