There is this nice sharing feature in ArcGIS Online for Sharing with your entire organisation, pretty stock standard feature very useful. Collector for reasons unknown ignores this feature, you must share your maps to a group that your users must also be a member of. This is just getting crazy with the amount of hoops you need to go through to share content with collector.
Can someone please explain to me why this is intended behaviour?
Collector for ArcGIS
"Note:
In addition to the data requirements, a map appears in Collector if you created it or if you are a member of a group with which the map is shared in ArcGIS Online or ArcGIS Enterprise. The map must also be enabled for use in Collector."
If you don't want content in collector just untick the use in collector box on the map....
Isn't your organisation the first group you are a member of?
