We are experiencing slow increases in memory usage on our ArcGIS Monitor VM. Once it reaches ~75% memory usage the paging file usage for that VM also slowly begins to increase as well. If this is left unattended the Monitor instance becomes unstable, crashes and requires a reboot. Once restarted the application stack restores correctly and behaves normally. The resolution to it is to ensure we reboot the Monitor VM every fortnight or so.
It is highly likely this issue is due to my infrastructure environment and/or custom extensions we are calling from the app.
Has anyone else encountered similar issues?
