Today I'm working in Spyder just like any other day but when I try to import arcpy, I get this:
<SPAN class="keyword token">import</SPAN> datetime
<SPAN class="keyword token">import</SPAN> os
<SPAN class="keyword token">import</SPAN> arcpy
Traceback <SPAN class="punctuation token">(</SPAN>most recent call last<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
File <SPAN class="string token">"<ipython-input-3-5467a3dc9fe3>"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN>
File <SPAN class="string token">"C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">72</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">from</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>geoprocessing <SPAN class="keyword token">import</SPAN> gp
File <SPAN class="string token">"C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\__init__.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">14</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">from</SPAN> <SPAN class="punctuation token">.</SPAN>_base <SPAN class="keyword token">import</SPAN> <SPAN class="operator token">*</SPAN>
File <SPAN class="string token">"C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">14</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">import</SPAN> arcgisscripting
RuntimeError<SPAN class="punctuation token">:</SPAN> Not signed into Portal<SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I imported datetime & os just to see if they worked okay and they do; I get this error if I let the console window sit long enough. I'm curious what the connection is with arcpy, spyder, python and Portal/ArcGIS Online is and how I can avoid this in the future....
eta moments later.... Shut down spyder and reopened it: cured.... (?)
