I trying to deploy Water Outage Components solution. I follow the instruction provided in ESRI guide and a created geometric network using tools and finally trying to generate web isolation tool. Unfortunately, running the tool I got these error message.
Running script GenerateIsolationTraceToolbox...
34 sources have been found in the source layer(s). To increase performance, it is recommended to reduce these to the minimum number of required sources.
File "<string>", line 649, in execute
AttributeError: module 'arcpy' has no attribute 'RefreshCatalog'
Failed to execute (GenerateIsolationTraceToolbox).
Then I uninstalled ArcGIS pro and try again and same error message shown up again. Python interactive terminal I can import arcpy with out any errors.
