Hi,I have a problem while trying to load FileGDBAPI.dllOur software is not dependant on Microsoft VC 9.0 dlls, it is built using VS2010 and it uses FileGDB binaries from "File Geodatabase API 1.2 version for Windows (Visual Studio 2010)" (FileGDB_API_VS2010_1_2.zip).After installing on clean Windows Server 2008 R2 machine it fails to load some dlls that links to FileGDBAPI.dll with errors in the event log:"Activation context generation failed for "C:\Program Files\...\FileGDBAPI.dll". Dependent Assembly Microsoft.VC90.CRT,processorArchitecture="amd64",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8" could not be found. Please use sxstrace.exe for detailed diagnosis."and indeed there is embedded manifest in this dll which says that it is dependant on Microsoft.VC90.CRTusing this command>mt.exe -inputresource:"C:\Program Files\...\FileGDBAPI.dll";#2 -out:extracted.manifest
I get a result:<?xml version="1.0" encoding="UTF-8" standalone="yes"?> <assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0"> <trustInfo xmlns="urn:schemas-microsoft-com:asm.v3"> <security> <requestedPrivileges> <requestedExecutionLevel level="asInvoker" uiAccess="false"></requestedExecutionLevel> </requestedPrivileges> </security> </trustInfo> <dependency> <dependentAssembly> <assemblyIdentity type="win32" name="Microsoft.VC90.CRT" version="9.0.21022.8" processorArchitecture="amd64" publicKeyToken="1fc8b3b9a1e18e3b"></assemblyIdentity> </dependentAssembly> </dependency> </assembly>
after installing "Microsoft Visual C++ 2008 Redistributable Package (x64)" those dlls get loaded just fine, but the question I have maybe someone knows a way to avoid installing this package? I checked also binaries from "File Geodatabase API 1.3 version for Windows (Visual Studio 2010)" and "File Geodatabase API 1.3 version for Windows (Visual Studio 2012)" but they also seem to be dependant on VC 9.0 runtime...
