I'm testing out this new widget and have had success with the actual costing portion. However, I'm having trouble setting up the polygon Project layer. I've added the layer and the two supporting tables that are needed to track projects, making sure that I configured the exact field names and data types. I've made sure that all are editable in AGO, however in the widget setup it will not recognize the Project layer as editable. I try to click on the check box to make it editable but it will not work. The issue seems to be rooted deeper in AGO, there is odd behavior trying to edit a polygon layer even in just a web map without using the widget or web app builder.
Can anyone help/confirm?
