We have a custom search widget which calls additional libraries in its widget.js using jimu/loaderplugins to load jQuery and terraformer.
Looking at the network calls when the app is initiating the widgets in an older WAB dev edition app (v1.3) compared with a newer one (v2.5), the calls to Widget.js have now been appended with ?wab_dev=2.5 (i.e. the deployVersion as listed in the env.js of the application).
This is causing issues with the loading of these extra libraries (access is denied and the widget fails to startup). Commenting out the deployVersion line in env.js throws an error.
Is there a way to disable that? Or alternatively, is there a updated method for loading additional libraries (in order) from the widget?
Regards
