Trying to figure out what the class_field variable is in this query
- fc is the Feature Class
- Class_field is WHAT?
- name_field is the field value?
<SPAN class="keyword token">import</SPAN> arcpy
fc <SPAN class="operator token">=</SPAN> <SPAN class="string token">'c:/base/data.gdb/roads'</SPAN>
class_field <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Road Class'</SPAN>
name_field <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Name'</SPAN>
<SPAN class="comment token"># Create an expression with proper delimiters</SPAN>
expression <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddFieldDelimiters<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> name_field<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">' = 2'</SPAN>
<SPAN class="comment token"># Create a search cursor using an SQL expression</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN>class_field<SPAN class="punctuation token">,</SPAN> name_field<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
where_clause<SPAN class="operator token">=</SPAN>expression<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># Print the name of the residential road</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
