Hi, I'm a newbie getting my feet wet with creating JavaScript Applications and it seems I know just enough to make a small amount of headway and then get stuck. On a current project I'm working on, I'm trying to create a simple embeddable map using a web map made in AGOL.I'd like both the search and home button widgets in the map as well.https://github.com/Esri/arcgis-dijit-home-button-jshttps://github.com/Esri/arcgis-dijit-geocoder-jsI'm currently able to create a generic web map with both of these widgets, but when I try and create a web map by id, I end up getting nothing back. See my code attached, anyone have any suggestions?<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Web Map</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
<style>
html, body, #map {
height:400px;
width:100%;
margin:0;
padding:0;
#HomeButton {
position: absolute;
top: 95px;
left: 20px;
z-index: 50;
#search {
display: block;
position: absolute;
z-index: 2;
top: 20px;
left: 74px;
</style>
<script src="http://js.arcgis.com/3.9/"></script>
<script>
var map,
webmapId = "1a40fa5cc1ab4569b79f45444d728067";
var geocoder;
require([
"esri/map",
"esri/arcgis/utils",
"esri/dijit/HomeButton",
"esri/dijit/Geocoder",
"dojo/domReady!"
], function(Map, arcgisUtils, HomeButton, Geocoder) {
arcgisUtils.createMap("1a40fa5cc1ab4569b79f45444d728067", "map").then(function (response) {
map = response.map;
home = new HomeButton({
map: map
}, "HomeButton");
home.startup();
geocoder = new Geocoder({
map: map
}, "search");
geocoder.startup();
</script>
</head>
<body>
<div id="map" class="map">
<div id="HomeButton"></div>
<div id="search"></div>
</body>
</html>
