Apologies, I understand this is a basic issue but it confuses me. I have a script tool which I am writing in python to work with a particular MXD. In this script tool I have the following lines of code to reference two layers in the MXD's TOC.
subjectLayer = arcpy.mapping.ListLayers(mxd,subjectlayerName)[0]
subjectLayer.definitionQuery = ""
cadastralLayer = arcpy.mapping.ListLayers(mxd,"Cadastre")[0]
arcpy.AddMessage( cadastralLayer) #To test if layer is set correctly
cadastralLayer.definitionQuery = ""
The subjectLayer object gets set correctly. This is chosen as a parameter in the tools UI. The definition query also gets set correctly.The cadastralLayer object gets populated also (AddMessage shows grouplayername\layername) but I get a "Script failure: 'unicode' object has no attribute 'definitionQuery'" error when it tries to set a definition query on it. This object is set by referencing the layer name in the TOC.
My question is why is one a unicode and the other a layer object as they were both referenced using ListLayers? How do I correctly reference layers in the TOC?
Thanks in advance.
