Having an issue with routing and secured route service. I have a simple Objective-C app with one view and am using iOS_100_3 version of the sdk. In viewDidLoad I am basically doing the following. When I run this I get the following error from loadWithCompletion
Error Domain=com.esri.arcgis.runtime.error Code=18 "Internal error" UserInfo={NSLocalizedFailureReason=Cannot get required value. Probably, invalid JSON., NSLocalizedDescription=Internal error, Additional Message=Cannot get required value. Probably, invalid JSON.}
Using this same basic code but replacing the route url with
https://sampleserver6.arcgisonline.com/arcgis/rest/services/NetworkAnalysis/SanDiego/NAServer/Route
I do not see the above error, I get another error which is expected as the code is not complete.
I feel it might be related to how I am authenticating with the route service, but am not sure as the error only tells me JSON might be invalid.
Has anyone here seen this or have any suggestions? Thanks.
NSURL *routeTaskUrl = [NSURL URLWithString:@"http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/"];
self.routeTask = [[AGSRouteTask alloc] initWithURL:routeTaskUrl];
AGSCredential *cred = [AGSCredential credentialWithUser:@xyz password:@xyz];
[self.routeTask setCredential:cred];
[self.routeTask loadWithCompletion:^(NSError *error){
if(error)
NSLog(@"%", error.localizedDescription);
else if(self.routeTask.loadStatus == AGSLoadStatusLoaded)
NSLog(@route task loaded);
[self.routeTask defaultRouteParametersWithCompletion:^(AGSRouteParameters * _Nullable routeParams, NSError * _Nullable error) {
if(error)
else
self.routeTaskParams = routeParams;
[self.routeTask solveRouteWithParameters:self.routeTaskParams completion:^(AGSRouteResult * _Nullable routeResult, NSError * _Nullable error) {
if(error)
else
// do something with it
