I programmed an initial add in in Python that works just fine. My problem is that when I make a trivial refactoring change to it, it fails to load in ArcGIS desktop.
The docs point to this being a syntax error in the code, but I checked it outside of ArcGIS and it worked just fine. I also couldn't find any information on ArcGIS (error logs, for example) about what the syntax error could be.
What can I do to find the cause of this problem? Can I find anywhere in ArcGIS a detailed error message about why this fails to load?
I post below how I refactored my code in case anyone can give me a hint about what could be wrong.
Before refactoring:
import arcpy
import pythonaddins
class Promedio(object):
"""Implementation for AddinsPyPromedio_addin.Promediobutton (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
def onClick(self):
#Compute average
After refactoring:
import arcpy
import pythonaddins
"""Implementation for AddinsPyAverage_addin.Averagebutton (Button)"""
def __init__(self):
self.enabled = True
def computeAverage(self):
#compute average
def onClick(self):
self.computeAverage()
