I have a Web AppBuilder Dev Edition 2.13 Foldable Template app that includes Select and Layer List tools. The widgets work fine in the WAB-DE GUI and local host, but when I publish to to the webshare then the check boxes in the select tool dissapear, as do the Search Button and layer description icons (three little dots to the right) in the Layer List. The elevation Profile tool is also missing the 'download' button. This is a button config issue I am not sure how to resolve it.
Is this a proxy issue? I have replicated the issue in v2.14 with same result in a new template based app with only those two tools. What could be causing this?
Thanks!
A
