I'm trying to add a Search widget to the base Esri Angular example. Essentially trying to combine:
GitHub - Esri/angular-cli-esri-map: Example Angular component for building mapping applications with the ArcGIS API for …
with
ArcGIS API for JavaScript Sandbox
to add a search widget in the Angular example. Within esri-map.components.ts I have this (my additions in bold below). Compile error is: Namespace '__esri' has no exported member 'SearchWidgetProperties'. I realize this may be an Angular question but how can I see a list of valid exported entities? And how would I hook up the search widget to the map in this context? Thanks for any help getting me pointed in the right direction.
esri-map-components.ts:
public ngOnInit() {
loadModules([
'esri/Map',
'esri/views/MapView',
'esri/widgets/Search',
.then(([EsriMap, EsriMapView, EsriSearch]) => {
// Set type for Map constructor properties
const mapProperties: esri.MapProperties = {
basemap: this._basemap
let map: esri.Map = new EsriMap(mapProperties);
// Set type for MapView constructor properties
const mapViewProperties: esri.MapViewProperties = {
container: this.mapViewEl.nativeElement,
center: this._center,
zoom: this._zoom,
map: map
let mapView: esri.MapView = new EsriMapView(mapViewProperties);
let searchWidget: esri.Search = new EsriSearch();const searchWidgetProperties: esri.SearchWidgetProperties = {
view : mapView
mapView.ui.add(searchWidget, {
position: 'top-right'
mapView.when(() => {
// All the resources in the MapView and the map have loaded. Now execute additional processes
this.mapLoaded.emit(true);
}, err => {
console.error(err);
.catch(err => {
console.error(err);
} // ngOnInit
