In my IOS app i've drawn a number of graphics onto the Map. In the TouchesBegin event that is fired when a user interacts with the map i cant figure out how to tell if the point interacts with one of the graphics.
I've binded the SDK to C#. The objects and the process should be the exact same as in a natively developed app
public override void TouchesBegan(NSSet touches, UIEvent evt)
if (!this.Loaded) return;
try
base.TouchesBegan(touches, evt);
var touch = touches.AnyObject as UITouch;
if (touch == null) return;
var p = new AGSIdentifyParameters()
Tolerance = 20,
Dpi = 98,
LayerOption = AGSIdentifyParametersLayerOption.All
var identityPoint = ToMapPoint(touch.LocationInView(this));
p.Geometry = identityPoint;
p.SpatialReference = identityPoint.SpatialReference;
p.MapEnvelope = this.MaxEnvelope;
p.Size = new CGSize(UIScreen.MainScreen.Bounds.Height, UIScreen.MainScreen.Bounds.Width);
//AFTER HERE IS WHERE I AM GETTING LOST. IM NOT SURE HOW TO FIND THE GRAPHIC I WANT TO INTERACT WIT
var gs = GraphicsLayer.SelectedGraphics;
var result = GraphicsLayer.Graphics.FirstOrDefault(i => i.Geometry.Envelope.ContainsPoint(identityPoint));
if (result != null)
var r = result.Geometry;
catch (Exception ex)
Analystics.Instance.LogError(ex,"Issue occured in the ontouch event on the Map");
